Component Identification?
Discussion in 'Radio Circuits, Repair & Performance' started by W4FBI, Sep 18, 2019.
  1. W4FBI
    W4FBI Ham Member QRZ Page
    I thought I was pretty good at reading schematics. C= capacitance R= resistance, etc.
    I am working on a Flex 5000A Antenna Tuner (schematic attached). It lists L12 as 'W950'. L usually means inductor. In this case, I think it means some sort of Ferrite. Several of the regular inductors are listed in uH (as expected).
    There is no Parts List associated with this schematic - so, I'm not sure what a W950 is.
    Seems there are two types on the schematic; W950 and W650
    It's a surface mount - guessing 1206 size
    Any thoughts on this?
  2. K7JEM
    K7JEM Ham Member QRZ Page
    Probably a ferrite bead over a piece of wire.
    IK8TNG and WA7PRC like this.
  3. K7MEM
    K7MEM Ham Member QRZ Page
    Judging from their position in the circuit they are probably surface mount ferrite beads. The numbers are possibly just part numbers.
  4. W4FBI
    Well, I think you guys are correct.
    I measured the DC resistance of the good W950 - about 0.3 ohms. (Ferrite)
    I now believe the '950' nomenclature might represent the impedance of the device. I looked them up at Mouser.com and they all have a DC resistance of less than an ohm, but the impedance varies with the model of the device.
  5. AA3EE
    AA3EE Ham Member QRZ Page
    W usually indicates a wire jumper. Could be a 0 ohm resistor. Or an SMD inductor, especially where they're at in the schematic. Pick something with a high impedance at HF, it's not a tuned circuit so the value isn't critical. It's there to stop noise.
  6. AG6QR
    That is probably impedance at 100MHz. That's a common way of rating small ferrite beads. The impedance at a different frequency will vary widely, and it's not just a simple formula like it would be for an air core inductor. See the data sheets.
    For example:
    https://uk.farnell.com/c/passive-co...on/ferrites-ferrite-assortments/ferrite-beads
