Clothesline Reel AKA Yo-Yo Antenna of Inslulated Wire
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by WI2D, Mar 21, 2010.
  1. WI2D
    WI2D Ham Member QRZ Page
    Dear antenna theorists and practitioners,
    My question is probably like one from the joke below.
    A student asked a professor one day:
    - Sir, when you sleep, do you put your beard above or below blanket?
    The old man replies:
    - Uh... I do not know. Never thought about it.
    Some time later they meet again and all exhausted professor jumps on the young fellow with accusation:
    - Because of your damn question, now I can not sleep at all: either way feels uncomfortable.
    So, here it goes.
    I have built a dipole of adjustable length similar to one described by KC8VWM. However, an insulated wire was used instead. Understanding that this approach creates coils at the end of each dipole leg, I am now debating whether I should strip the insulation. This way different turns of the wire on the reel will be in contact with each other eliminating the coil.
    Commercial 'Yo-Yo' variant of this antenna with insulated wire marketed by
    Should I worry about described coils and strip the insulation?
    Thanks & 73,
    WI2D - Andrey
  2. KC8VWM
    KC8VWM Moderator Staff Member Volunteer Moderator QRZ Page
    Hi Andrey,
    Since it's my portable antenna design you are constructing, I suppose I might be able to answer your question how it works. :)
    When you unroll the wire from the reel, it changes resonance in terms of it's operating frequency.
    This is the tuning aspect of this design. You will not require an antenna tuner to work every band from 40 - 6m using this antenna.
    The wire left inside the reel is really just a "metal ball" which exists at the end of the wire. This "ball" is similar to the one installed on the end of your car antenna.
    Bare wire works best for this project because the wire ball inside the camping reels becomes a resonant part of the actual antenna design. It is because of that fact insulated wire will not work for this design.
    You need to include the "metal ball" inside as it extends to the rear of the reel as it's a functional part of the actual antenna length.
    Design Instructions:
    First, start out by designing the entire wire antenna to function on 40m as an ordinary dipole. (around 32' 11' when fully extended from the reels) 14 gauge flexweave is used in this design however "thinner" wire may be used. Stranded is typically better than solid wire because it's usually mechanically stronger and resists kinking etc.
    Once we design a 40 m dipole, next, we want to reel in just the right amount of wire for it to reach and function on the 30m band.
    For example, since we know a 40m dipole is 32' 11" and if a 30m dipole is 23' 2" long, then we simply subtract the difference and that's where the 30m band will be located on the wire. (subtract around 8' 9" +/- )
    Next, check and tweak for best VSWR on the 30m band by adjusting the wire a few inches +/- in or out of the reels on both sides of the dipole until the best VSWR has been achieved at the desired operating frequency.
    Next use a paint marker, to mark that spot on each side of the dipole at the point it folds over the tab on the end of the reel for future reference. (see photo below)
    Now "tune" the antenna again but do this calculation for the next band when going from 30m to 20m.
    For exmple, to adjust the antenna from 20m to 17m all you need to do is calculate the differences in terms of wire length required between the next two bands in order to find how much wire needs to be reeled up inside. (subtracted.)
    For example.
    If one leg of a dipole cut for 20m CW portion of the band is:
    16' 7" long and if
    One leg of a dipole for 17m CW portion of the band is
    12' 11" long
    And if the antenna has a good VSWR reading on the previous band, then collapse the wire inside the reel exactly 4' 2" and that will be the difference between operating on 20m to 17 meters.
    Once you have done that, check the VSWR again, (tweak the wire length and inch in or out of the reel if necessary) and now mark that spot on the antenna wire using the paint marker.
    Lather, rinse, repeat. :)
    Do the same thing above but for changing bands from 17 to 15 meters.
    Next you adjust and mark the wire going from 15 to 12m
    12 to 10m and so on...
    Complete the calculations and wire marking procedure on every band until you have markings on your roll up antenna wire for every band from 40m though 6 meters.
    You can also include and mark it for 2 meters if you like!
    Now to operate on a regular basis using ONE high performance and lightweight portable antenna for every amateur radio band from 40 - 2m AND without requiring any tuner, all you need to do is count how many wire marks it takes to operate on a particular band.
    For 40 meter operation, you simply unroll all the wire from the entire reel. (no paint marks required)
    30 meters = 1 paint mark on each side of the dipole
    20 m = #2 paint mark
    17m = #3 paint mark
    15m = #4 paint mark
    etc etc..
    It's just that easy... :)
    Please let me know if you or anyone else has any questions or needs additional assistance with this portable multiband antenna design.
    My Best.
  3. WI2D
    Thank you for posting the detailed description of the antenna construction.
    Using bare wire was exactly my intent. But because I could not find thin stranded buss wire I went with the insulated one.
    The sleek Teflon insulation makes the wire convenient to work with and protects its strands from being separated and broken.
    Looking at it now I am wondering is it really worth it to strip the insulation?
    Unless there is a good advice against stripping, I will do it just to remove the doubt. At the end, worn out wire is easy to replace.
    WI2D - Andrey
  4. KC8VWM
    Yes, any wire you have available will do the job just as long as it's bare.
    Insulation means the wire is thicker in terms of limiting how much wire can be stuffed into the reels. So basically, more bare wire will go inside the reels without any difficulty.
    To make the "knot" on the inside of the reel to keep the wire from slipping off the end of the reel when fully extended, simply twist the end of the wire on the inside of the reel around a #6 nut and solder.
    Another tip, place a smudge of white lithium grease along the "friction points" on the inside of the camping reels. This is located between the outer "track" edge of the inner spinning yellow reel and the outer shell it rides along. This helps ensure the reels will always function with ease.
    My Best,
  5. LA3AKA
    LA3AKA Ham Member QRZ Page
    It shouldn't make any big difference between using insulated or stripped wire for this kind of antenna. since the inductor is at the end of the antenna it has very little effect on the resonance frequency of the antenna. The length of the antenna might be a little bit shorter with isolated wire due to the velocity factor for isolated wire (3-4% depending of thickness of wire and isolation and type of isolation), but this should not cause any problem as you can adjust the length very easy. If you can fit enough wire inside the reel without stripping off the insulation, I would not bother doing it.
    73 de LA3AKA
  6. G0GQK
    G0GQK Ham Member QRZ Page
    I thought Aka Yo-yo was a Japanese pop star.
  7. WI2D
    Thank you for your comment.
    So, the dipole length can not be used as an exact reference of proper antenna configuration and SVR should be measured for final tuning.
    It appears that presence of relatively small artifacts at the leg ends will just slightly affect the resonating length of the antenna.
    Could anybody point to a theoretical basis for this?
    WI2D - Andrey
  8. KJ6FOB
    KJ6FOB Ham Member QRZ Page
    Sorry for the simplistic question, but how do you power this antenna? Thanks...
  9. KC8VWM
    I think what you are asking is how the antenna is fed (powered) at it's feedpoint.
    This is a typical hardware store schedule 40 - 2” PVC cap with stainless steel eye screws attached on each side. The S0-239 connector is installed as illustrated.
    Installed on a 20 foot aluminum telescopic "painters" extension pole. Note the loop installed on top of the PVC cap enables you to suspend the feedpoint up in a tree.
    Portable lightweight multiband antenna system.
    Everything fits inside this nylon zip up bag. Including the LMR-200 feedline!
    This is not yet another "compromise" portable antenna design. It's a maximized performance portable antenna system. I doubt many other shorter and commercially made portable antenna designs can compare in terms of thier performance and yet somehow pack up into a small package of similar size.
  10. LA3AKA
    As you move out from the center of the dipole the current decreases and the voltage increases this means that the impedance also increases. In order to compensate for the increased reactance you will have to increase the impedance to null out the capacitive reactance. At the end of the antenna the current will be 0 (ideally) or close to zero. this will give a very high impedance/reactance and thus a very high inductance is needed to null out the reactance. For a shortened dipole, the further from the load point you place the inductor, the bigger it will have to be because of the increased reactance. If you put the loading coil at the end of the antenna legs it needs to be very high. Because of this a coil at the end of an antenna leg have little influence on the resonant length of the antenna.
    73 de LA3AKA
