can't connect
Discussion in 'Ham Radio Deluxe - HRD' started by KC2EMW, Apr 19, 2017.
  1. KC2EMW
    KC2EMW Ham Member QRZ Page
    running icom7200 with mfj1279, dell optiplex748 with win xp pro, computer communicates with sound card interface, but i get error message when trying to acess hrd, frequency not found, have tried usb and comport, and auto detect on hrd, checked audio levels, but nothing seems to work
  2. KB1NXE
    KB1NXE Platinum Subscriber Platinum Subscriber QRZ Page
    Have you installed the drivers from Icom on the Laptop so it can see the radio?
    Instructions are in the Icom users manual and on their website.
  3. KD9CKB
    KD9CKB Ham Member QRZ Page
    why use the mfj soundcard unit? the icom7200 has a built in soundcard from the usb port
  4. KF2M
    KF2M XML Subscriber QRZ Page
    There is no need for the MFJ device. HRD can access the radio via the USB port. Install the USB drivers (linked below), connect the radio, after Windows detects and loads the radio driver check Windows Device Manager for the COM Port Windows assigned to the radio. In HRD select the radio, COM Port, the radios' hex address, and baud rate (set both the radios' CI-V Baud Rate in Set Mode, and HRD to 19200).
    USB Drivers: http://www.icom.co.jp/world/support/download/firm/IC-7600/usb1_20/
    Helpfile: http://www.greggeek.com/Radio Configuration for Digital Modes.pdf
    KD9CKB likes this.
  5. KC2EMW
    thks all for info, but the icom 7200 has no comport on back of radio, only civ port, and their is no menu available for port or port settings, the manual says it needs external sound card to do digital other than psk and cw
  6. KA9JLM
    I think it is USB. (4)
  7. KF2M
    Plug a USB cable into the back of the radio, and the other end into your computer and you'll have a COM Port (as long as you have the drivers loaded otherwise Windows will dump it in the Others section of Device Manager).
    USB = Universal Serial Bus
    RS-232 ports are being replaced with USB ports on newer radios.
  8. KB1NXE
    Please refer to page 9, item 1 of the IC-7200 user manual.
