ad: Hamcestry-1
Can I use a 40 meter dipole on 20 and 15 meters?
Discussion in 'General Technical Questions and Answers' started by W6IRE, Apr 29, 2009.
  1. W6IRE
    W6IRE Guest
    I'm looking at the Force 12 "Sigma 40" 40 meter vertical diplole...
    Presumably, this antenna is a half wavelength at 40 meters, so with an antenna tuner (or not) would I be able to use it on 20 meters? Also, since 15 meters is a third harmonic, could I use this antenna on 15 meters?
    Also, could I listen (not transmit) to 75 meters?
    Many thanks in advance!
    73...............Richard
  2. K9STH
    K9STH Ham Member QRZ Page
    IRE:
    The antenna should work fine on 15 meters as a 3/2 wave antenna. However, on 20 meters or 10 meters the antenna is going to present a very high impedance to a coaxial cable feedline. You might be able to use an antenna tuner to "match" your transmitter to whatever impedance the feedline presents at the transmitter end. However, the line losses in the coaxial cable will definitely be considerably higher than when operated on 40 or 15 meters.
    As for receiving on 80 meters, it should work fairly well. But, to transmit using the antenna you will definitely need to use an antenna tuner and the performance may be anything from OK to really dismal. You just will have to try to load the antenna with your tuner/transmitter arrangement and see what happens.
  3. WW3QB
    WW3QB Ham Member QRZ Page
    I've tried a horizontal wire 40m dipole. I could tune it with a tuner, but it was worse than dismal on 80m and 20m. Very good on 15m, and great on 40m (or it wouldn't be a 40m dipole). It was also pretty good with a tuner on 30m and fair on 17m. Not bad for a single wire antenna. The math should be the same with a vertical dipole.
    Edit: Since this vertical dipole is only 24 feet tall, I'm not so sure how it will perform on other bands (or even 40m). That is shortened.
    Edit #2: $749.00?!
  4. W6IRE
    W6IRE Guest
    Thanks guys! Yeah, that price is a bit high, reviews at eHam say guys are paying about $488
    Thanks again, guys!
  5. WA9CWX
    WA9CWX Ham Member QRZ Page
    people are paying nearly $500 for a 40 meter vertical dipole ?????
    I have a pair of phased 40 meter verticals, with 60 radials, and a 'perfect' :) matching system the whole shebang must have cost me about $300 including some nice aluminum and heavy duty mounting system. :confused:
  6. AI3V
    AI3V Ham Member QRZ Page
    Yikes, Thats a lotta $$$ ! :eek:
    You can homebrew a 40M vertical for WAY less $$$
    That sigma40 will work "OK" anywhere above 40M- The issue will be a high VSWR causing extra loss in the coax. The antenna is already "short" on 40M,but not too bad, 80 and 160 will be a exercise in frustration.
    Rege
  7. KJ3N
    KJ3N Ham Member QRZ Page
    Funny, sad, and amazing..... all at the same time.
    P. T. Barnum reigns supreme!
    For 1/10th of the cost, an ARRL Antenna Book (and some of your time) is a wise investment.
  8. KA4DPO
    KA4DPO Premium Subscriber QRZ Page
    Unless you just like weird antennas, you can get a Butternut HF6V for a little less money and it's only 26 feet tall (2 feet higher than the Sigma). It will work 80 through 6 meters and my experience with that particular antenna has been very good. The only difference is you will need to put down a reasonable number of radials to make it work well. The best part is you won't need a tuner.:)
  9. AG3Y
    AG3Y Guest
    The best part is that it doesn't cost $500 ! ! ! Does it ?
  10. W5DXP
    W5DXP Ham Member QRZ Page
    Why is a 3/2WL vertical dipole on 15m a bad idea? Because the take-off-angle is high and most of the RF is lost in space. At the low of the sunspot cycle, 15m needs all the help it can get from low-angle radiation. For a vertical center-fed dipole, the length needs to be 1.25WL (or less).
