ad: Mountaingoat-1
Broadband Terminated Dipole Antenna for ALE
Discussion in 'Amateur Radio News' started by OH8STN, Aug 19, 2017.
  1. OH8STN
    OH8STN Ham Member QRZ Page
    Funny you should mention this. I tested an antenna from a company who sold it on ebay some time ago. I couldnt understand why icicles kept forming around the transformer and load, but then ... heat! It wasn't a very good performer anyway, so i sent it back. After that experience I thought I should get one of those laser thermometers, but had forgotten about it until you mentioned it.
  2. KZ3H
    KZ3H Ham Member QRZ Page
    Good work, I hope to link up with you. I did a demo with the x108G radio (20 watts) and end fed Hybrid into the American Legion net last weekend - great signal reports. I should have the t2fd antenna hooked to a CODAN ALE radio this month.
    de KZ3H
    OH8STN likes this.
  3. OH8STN
    Thanks,
    Thanks, but it sounds like you're doing all the work hi. That CODAN is a dream radio!
    I just switched the configuration to sloping Vee, West & South. I'm hoping to catch some of the special ale Eclipse activity from NA.
    de oh8stn
  4. DL2FDJ
    DL2FDJ Ham Member QRZ Page
    I own a CHA TD along with some other Chameleon antennas. The only Chameleon antenna I still use today is the F-Loop. All the other antennas following the 5:1 transformer model sit packed away in some corner. I tested for years but the efficiency was just bad. Recently I compared a 1/4 wave homebrew vertical for 20m with the cha hybrid mil whip plus extension using WSPR. Stunning how much more efficient my little $5 wire vertical was. Sure the Chameleon 5:1 typ antennas are sturdy and work for the most part without a tuner but i am not in a shtf scenario. And even if I ever have to deal with shtf, a bit of wire and coax and I am on the air. Don't get me wrong, Chameleon makes very well made equipment but the whole 5:1 stuff is just too inefficient and I can travel lighter and transmit more efficient with some linked dipole and a 6m fiberglass mast.
  5. KM4DYX
    KM4DYX Ham Member QRZ Page
    I'm a fan of the linked dipole/fiberglass mast solution as well (as I might have mentioned before; I tend to repeat myself in my old age.)
    But the OP's point about ALE is valid. ALE presents a bit of a conundrum in the antenna system department, particularly for portable operations. I'm still pondering this one.
  6. DL2FDJ
  7. OH8STN
    Nice Page Chris. How much does the entire system weigh, & how long would it take a single person to set up? It looks very interesting but isn't it lacking the configuration options and portability in comparison to the BBTD or T2FD?
    My goal is to use a single spiderbeam 12m mast for antenna support. The ground rods make the system easier to deploy, but introduces more weight for field use. I also would not like fiddling around trying to push metal rods into frozen ground (65°N) during the winter. Did you mean this as a fixed installation? I also noticed your transformer and the termination resistors for sale on your website. How about some pictures on your website?
    Thanks for sharing.
    Julian oh8stn
  8. KQ6XA
    KQ6XA Ham Member QRZ Page
  9. WB4ENE/SK2022
    WB4ENE/SK2022 Ham Member QRZ Page
    WB4ENE writes:
    Military stns are "communicators", not "hams" or "broadcasters" the "important things" are different for each of these station personality types ;)
    I'm pulling one of my T2FD NEC models and will find the power loss in the resistor right now. Hams and Broadcasters get wrapped around the Tx power loss, but the Communicator looks at the drop in QRN levels, which improve their Rx ability. You can always bump up the Tx power, but its kinda hard to get the neighbor to unplug his fishtank heater!
    Ok,got it:
    131 foot long terminated dipole at 45 feet elevation:
    spacing between the two wires that are vertically separated: 14 inches
    load/terminating resistor in center of the top wire: 900 ohm
    450 ohm transformer/feed
    100 watts Transmit power to the source:
    4Mhz: pwr in resistor causing icicles: 71.7W - 900 ohm resistor
    swr: 3.6 : 1 at the 450 balun
    5Mhz: pwr in resistor causing icicles: 65.0W
    swr: 4.1 : 1
    7MHz: pwr in resistor causing icicles: 66.5W
    swr: 1.7 : 1
    10Mhz: pwr in resistor causing icicles: 73.7W
    swr: 2.3 : 1
    change the load resistor to 450 ohms Tx pwr 100 watts
    4Mhz: pwr in resistor causing icicles: 56.5W - 450 ohm resistor
    swr: 3.5 : 1 at the 450 balun
    5Mhz: pwr in resistor causing icicles: 55.8W
    swr: 6 : 1
    7MHz: pwr in resistor causing icicles: 78.3W
    swr: 1.9 : 1
    10Mhz: pwr in resistor causing icicles: 65.3W
    swr: 3.2 : 1
    Change the transformer to 600:50 ohm
    and Load resistor to 450 ohms:
    swr: 2.7 : 1 at the 600 balun
    5Mhz: pwr in resistor causing icicles: 55.8W swr: 4.6 : 1
    7MHz: pwr in resistor causing icicles: 78.3W swr: 2.0 : 1
    10Mhz: pwr in resistor causing icicles: 65.3W swr: 2.4 : 1
    You can tune VSWR overall shape by swapping out what transformer ratio you use. So, have a 200/300/450/600 balun available. Sweep, swap, sweep
    Ken WB4ENE
  10. AG7UF
    AG7UF Ham Member QRZ Page
  11. KQ6XA
    For the standard BBTD antenna with the feedpoint about 30 feet above ground, there's +3dB radiation advantage to putting the (16:1 balun) feedpoint at the top .
    On 7 MHz, for the Inverted-V Delta Wing configuration of BBTD antenna, there is approximately +4 to +6 dB ERP advantage to feeding it at the top, mainly due to ground losses.
    As the overall height of the wires of the antenna is increased, there is somewhat less advantage to feeding it at the top.
    But, for SWR, it doesn't matter much whether you feed it at the top or bottom.
    You can lay the antenna on its side also.
    It provides good broadband SWR anyway.
