Best Wire Antenna?
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by N5RWJ, Dec 19, 2011.
  1. N5RWJ
    N5RWJ Ham Member QRZ Page
    What is your best wire antenna?
  2. N8WWM
    N8WWM Ham Member QRZ Page
    Best wire antenna for doing what, specifically?
  3. NA0AA
    NA0AA Ham Member QRZ Page
    All of 'em.
    What to be a bit more specific? Performance per foot of wire or something?
    I have a loop, dipoles, end fed wires, each serves a purpose. What do you want to do?
  4. AD7N
    AD7N Ham Member QRZ Page
    There's an easy formula. It goes like this:
    The simplest, highest altitude wire antenna that puts the most gain in the direction you want, on the bands you want and is either tunable with a tuner, or resonates below 2:1SWR where you want it.
    There you go :)
    The simplicity element may be the biggest key - how much time, money and effort are you comfortable putting into it?
  5. KC8VWM
    KC8VWM Ham Member QRZ Page
    A dipole. They are the next best thing to using a 2 element Yagi but with one less element.
    Could also be a hexbeam. ...It's a wire antenna right?
    Then again it could be a doublet or an OCF because they cover more bands than a monoband dipole.
    Then again it could be a monoband dipole because it operates more efficiently than a multiband antenna.
    It all depends on your perspective.
    Define "best" exactly.
  6. K9STH
    K9STH Ham Member QRZ Page
    The best wire antenna that I ever had was a true "Zepp" cut for the 160-meter band. A true "Zepp" has a half-wave (at the lowest frequency) radiating element and a quarter-wave of balanced feed line. It had about 270 feet of wire and was fed with "transmitting twin lead" (300 ohm twin-lead that could easily handle 1000 watts used to be available). The antenna worked well on 160, 80/75, 40, 20, and 10-meters. A true "Zepp" doesn't load well on 15.
    I was using first a WRL Globe Chief 90A and then a Heath DX-100, both of which can handle a very good range of antenna impedances (DX-100 up to over 600 ohms and the Globe Chief 90A up to over 1200 ohms).
  7. N0AZZ
    N0AZZ Ham Member QRZ Page
    I have 2 favorites one design I have used over 6 yrs it's a OCFD coax fed 270' mounted at 60' covers 160-6m it is a Buckmaster one of the most well made wire antennas I have ever seen. The other is a 160m loop coax fed @40' to low really but works great for all of NA, CA a little of S America very well one of the best I've ever had but not really a DX antenna such in my case anyway have worked a little EU and some Africa but that's it.
  8. WB2WIK
    It's always BENS BEST BENT WIRE
    Send that in code it sounds cool.
  9. KD4MOJ
    KD4MOJ Database Subscriber QRZ Page
    The one I made of course! :D
    ...DOUG
    KD4MOJ
  10. W5TTW
    W5TTW Ham Member QRZ Page
    I have several wire antennas, but my Carolina Windom is the one I use the most. It's a 40/20/10/6 that also works well elsewhere. 32 feet in an inverted V. Nearly invisible to the HOA, too.
