ad: Hamcrazy-1
Best way to mount an IMAX 2000?
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KC9VFO, Jul 13, 2012.
  1. KC9VFO
    KC9VFO XML Subscriber QRZ Page
    My friend gave me an IMAX 2000 to see if I wanted to use it for 10 meters. After some inspection I decided this was the best option.
    I'd clamp on a reel at the bottom and some line guides along the length, add a nice handle and bingo.
    "Whatcha castin' there, son?"
    "IMAX 2000."
  3. KC7YRA
    KC7YRA Ham Member Volunteer Moderator QRZ Page
    LOL. When I read the title of this thread, I was thinking "in the trash". Then I clicked in and saw the pic. LOL.
    At least pull the aluminum off and recycle it.
    Brad
  4. N3JBH
    N3JBH Ham Member QRZ Page
    Oh boy :rolleyes: this should get some response. Some folks think there darn great antenna's. Personally i tore it apart just to see what made it tick and salvage what i thought be useful like the mounting plate.
  5. WB2WIK
    There used to be some really great all-aluminum CB antennas in the good old days. Some law made them illegal years ago (electric shock hazard prevention stuff -- really silly). But I see some are coming back now as 10m amateur antennas, which are okay as aluminum.
    The old Antenna Specialists Super Magnum and such were very good. Sure a lot better than the Solarcon, IMAX, etc. At least they're making a comeback as ham antennas.
  6. W9GB
    You are missing the TWO Mast (Saddle) clamps - aluminum and stainless steel clamp will cost you about $6 to $10 each.
    Get out your TAPE MEASURE , take measurements, andthen select appropriate U-Bolt.
    DX Engineering has a wide selection for this type of repair.
    http://www.dxengineering.com/
    You then need a mast, at least 1-1/4 inch OD -- which is same size as TV antenna mast.
    w9gb
  7. KC9VFO
    Actually I robbed the U bolts and threw them in my junk drawer. :)
  8. K8JD
    K8JD Ham Member QRZ Page
    It would have been a good antenna to work local 10M FM repeaters. If you can set your A/B split freq to do 100 kHz split and switch the rig's mode to FM.
  9. KC7YRA
    Exactly. I would love an old, all aluminum vertical that I could put onto 10. These fiberglass jobbers just don't hold up here. Poor construction and lackluster performance.
    Brad
  10. N4BWD
    N4BWD Ham Member QRZ Page
    Send it to me! I want it!
    N4BWD
ad: SteppIR-1
