ad: M2Ant-1
BAOFENG UV5RA
Discussion in 'Amateur Radio Software' started by KR6AUL, Nov 16, 2012.
  1. KR6AUL
    KR6AUL XML Subscriber QRZ Page
    Hey all,
    I am trying to get the programming software for the UV5RA, I have not been able to use the software for the UV5R, every time I try it tells me it cannot communicate to the radio. Anyone have any suggestions or can send me a copy of the software. I have the proper drivers and cable installed(I think).
    Thanks
    Raul
    KG6YFS
  2. ZONE3
    ZONE3 QRZ Member
    Try this: http://www.miklor.com/uv5r/UV5R-Drivers.html
    I have that same radio...they ( exporter ) supplied a 3 inch CD ...if you have any further probs...I c an .ISO the disc for you...and you can burn it.
    Hope it works ( The Links ) for ya..
    73 OM
  3. KI6ZON
    KI6ZON Ham Member QRZ Page
    Try CHIRP - it's open source and written in English. You will need to download the most recent nightly build to work with a UV-5, but that worked fine for me.
    Get CHIRP here: http://chirp.danplanet.com
    -Sutter KI6ZON
  4. KR6AUL
    Well so far no luck. I tried with the cd that came with the cable, I tried the different drivers and right now I am downloading last nights build of CHIRP. I keep getting a error. I will copy the new error if there is one with the new build. This is supposed to be the newest radio which is the UV5RA...for some reason I just cant seem to get it to work. I am using Windows 8 and im wondering if that or the radio version that is causing the issue.
  5. K8ERV
    K8ERV Ham Member QRZ Page
    I see some 5Rs with suffix letters, anyone know what they mean?
    TOM K8ERV Montrose Colo
  6. KR6AUL
    I am getting radio did not respond error
  7. KI6ZON
    According to this web page, the only difference is firmware.
    Where are you getting that error? After clicking "Download from Radio"? Or after selecting the COM port and clicking okay?
    I tried to test it under my Evaluation Copy of Win 8, but it wouldn't allow me to install the drivers for the cable, so I couldn't get any farther.
    If it would be easier, feel free to email me at the address listed on my QRZ page.
  8. KD0TGA
    KD0TGA Ham Member QRZ Page
    KG6YFS, did you ever get this figured out? I was finally able to get my UV-5R+ programmed just yesterday and might be able to help you out.
  9. KR6AUL
    No still have not been able to get it programmed. How did you get it programmed?
  10. KD0TGA
    The main issue I had was the driver for the cable. For that, I used ZONE3's link (http://www.miklor.com/uv5r/UV5R-Drivers.html) and used the "Choose from a list of drivers" option as shown in his screen shots. The other issue was with the Com port... I noticed the Baofeng program doesn't save what COM port it goes into, so you have to configure that every time you run the program.
ad: portazero-1
