Astatic D-104 help
Discussion in 'Microphones, Speakers & Audio Processing' started by WQ2H, Dec 8, 2015.
  1. WQ2H
    WQ2H QRZ Lifetime Member #214 Platinum Subscriber Life Member QRZ Page
    Hi folks,
    I'm kind of new at this, but any ideas whether I have this "un-amplified" D-104 wired correctly for use with a Heathkit HW-101 ? I'd like to make sure it's correct before I just key it up.
    As a mechanical engineer I should stick to firearms and steam engines - but with HF radio I can't help but get my hand in. Thanks for the help ! [​IMG]
    Jim, kb1huo
  2. KD8DEY
    KD8DEY Ham Member QRZ Page
    White is audio + and shield is audio -
    Isnt there only 2 connections on a HW-101?...
    Is there a switched marked Relay in the bottom of the D104?
    trying to use the red and black wires to make/break vox??....
  3. WQ2H
    yes, what I have is:
    white - pin 1
    black - pin 2
    shield to - connector shell
    red - open
    I think the red is connected internally.
  4. KD8DEY
    I believe that red goes on 2
    and shield & black goes on the connector
  5. WQ2H
    So that would also allow the PTT to work?
    The mic was listed as:
    mic - red/wht
    ptt - blk/shield
  6. KD8DEY
    Believe so, and the switch inside should be set on relay.
    (Doesnt matter if the red & black are reversed with the bottom switch in the relay position BUT that is how it is listed in the Astatic book for the 101)
    If your mic doesnt have the little switch inside a little bit different wiring will be needed...
  7. WQ2H
    I'll give it a try.
    so, just to confirm:
    white - pin 1
    red - pin 2
    blk & shield - connector shell
  8. KD8DEY
    Did you check to see if there is a small switch inside the base of the mic?
    There are a few variations and some dont ....
    There have been so many incarnations/modifications by users etc over it's lifespan it's hard to know all the players without a scorecard or having it in front of you...
  9. WQ2H
    I'll take a look tonight - I got it without a connector, and labels identifying the wires. This is an older model I believe.
    Thanks for the help - I'll get back here tomorrow AM.
  10. W9GB
    Astatic Schematic Diagrams for Desk Stands (Factory Wiring)
    http://www.barovelli.com/projects/radio/radioastatic.htm
    The G-Stand base cable is: 2-conductor with Shield (red/white w/shield).
    The UG8 stand base cable is: 4-conductor with Shield (white/black w/shield; red/blue)
    Heil Audio "Heil Wire" is the same color/construction as the factory wire used on Astatic UG8 stand.
    http://www.dxengineering.com/parts/hls-hw-10
    Heath Kit HW-101 HF Transceiver microphone wiring (from HW-101 manual)
    The Amphenol 80MC2M is a 3-conductor connector.
    Pin 1 : Microphone Audio +
    Pin 2 : PTT + (switch)
    Shell : Audio and PTT Grounds
