ad: hrd-2
APRS + FT-1900R + UI-View32 + AGWPE - Cable Help!
Discussion in 'Working Different Modes' started by NIGHTHAWK98TJ, Jul 25, 2010.
  1. NIGHTHAWK98TJ
    NIGHTHAWK98TJ QRZ Member
    Hi All,
    I am attempting to setup a connection between my laptop and my Yaesu FT-1900R for APRS and I have run into a roadblock or sorts. I am running UI-View32 and AGWPE on the laptop and have been able to successfully receive APRS data and link my GPS to UI-View32, as well as configure the software to TX my location data via the soundcard. However, the point where I am stuck is where I make the input connection from the 1/8" audio jack to the RJ-11 mic jack on the FT-1900R.
    I have a diagram of the pins on the jack, but what I don't understand is how the computer will key the PTT wire on the jack and then transmit the data? Basically, I need to know how to build a wire between the RJ-11 and the 1/8" stereo or mono plug and make it work properly. Is this possible to do with this radio without a hardware TNC?
    Any help would be much appreciated!
    Thanks,
    Tim
    KI6TFI
  2. K9STH
    I would suggest getting your log in identification changed to your call. Doing so will give you a lot more posting privileges here on QRZ.com.
    Head Moderator QRZ.com
  3. N5NA
    N5NA Subscriber QRZ Page
  4. KC2UGV
    KC2UGV Ham Member QRZ Page
  5. NIGHTHAWK98TJ
    Could you point me in the direction of how to do so?
    Thanks,
    Tim
  6. NIGHTHAWK98TJ
    Thanks for the links, everyone!
ad: SDRKits-1
