ad: Sussex-1
AO-40 transponder tests a hit!
Discussion in 'Amateur Radio News' started by Guest, May 8, 2001.
  1. Guest
    Guest Guest
    From the ARRL...
    The inaugural AO-40 transponder tests have been a huge success.
    Reports from amateurs making their first contacts on AO-40 have come
    from all over. More are expected as the experimental operation
    continues.
    ''It was just great!'' enthused AMSAT-NA President Robin Haighton,
    VE3FRH, who worked a dozen or so stations via AO-40 over the
    weekend.
    AO-40 ground controllers opened up the next-generation satellite's
    transponders May 5 for general amateur use on an experimental basis.
    Stations can uplink on either 435 MHz or 1.2 GHz. The transponder
    downlink is at 2.4 GHz. The operation is experimental, the schedule
    subject to change, and the transponders could be shut down at any
    time without warning.
    Mike Seguin, N1JEZ, in Vermont, was first to report his contacts on
    the AMSAT bulletin board. ''I've successfully logged a dozen contacts
    in the first hour of operation, including two contacts using the
    Mode-L uplink,'' he said. Seguin said his final tally was 24
    contacts, including QSOs with Europe. ''A great first day! Let's hope
    for many more.''
    Ed Krome, K9EK, in Indiana, echoed N1JEZ's comments. ''Wow, AO-40 was
    terrific on this first morning of transponder operation,'' he said.
    ''After almost 10 years, what a thrill!''
    AO-40 may be available for use several hours a day, starting at MA
    136 and continuing through MA 240. During the weekend passes, the
    transponders were available for six hours or so from a given point
    on Earth.
    The tests have shown that uplink frequencies (without taking Doppler
    into account) are 435.495-435.780 MHz and 1269.211-1269.496 MHz, and
    the downlink passband is 2401.210-2401.495 MHz. The transponders are
    inverting, so a downward change in uplink frequency will result in
    an upward frequency shift in the downlink.
    Users are being asked to avoid the ''middle'' telemetry beacon at
    2401.323 MHz and give it a clearance of 5 kHz on either side. For
    maximum QSO signal strength, stations should aim for a passband
    signal that's 10 dB below that of the middle beacon.
    Following the transponder experiment, ground controllers plan to
    raise AO-40's perigee by approximately 200 km.
