AO-40 \"S1\" Transmitter Goes Silent
Discussion in 'Amateur Radio News' started by Guest, Aug 15, 2001.
  1. Guest
    Guest Guest
    From the ARRL...
    AMSAT reports the 2.4 GHz ''S1'' transmitter aboard AO-40 has gone
    silent. Ground controller Stacey Mills, W4SM, says the transmitter
    abruptly quit August 13 at around 1258z while AO-40 was in view of
    most of the Eastern Hemisphere during orbit 362.
    He reports normal telemetry readings up to the point that the
    transmitter ceased operating and that no commands were being sent or
    experiments under way at the time.
    An onboard scheduler switched on the S2 transmitter at the
    appropriate point in the spacecraft's orbit. Mills said subsequent
    telemetry indicated no abnormalities or logged events to account for
    the failure.
    The S1 transponder, connected to a higher-gain parabolic antenna,
    had been brought into the rotation to offer improved coverage when
    the satellite was farther away from Earth. The S2 transponder is
    connected to a helical antenna that has about 10 dB less gain than
    the parabolic antenna.
    An initial attempt to manually switch the S1 transmitter back on did
    not appear successful. While ground controllers continue to study
    the situation, the S1 transmitter has been taken out of the
    schedule. The U-band and L1-band to S2-band transponder passbands
    will remain active from MA 10 to MA 30 and MA 44 to MA 100. The
    RUDAK digital transponder is connected to the S2 transmitter, and
    the beacon is off from MA 30 to MA 44.
    ''The schedule may also be modified for longer passband periods,
    given the broader coverage of the S2 helical antenna,'' Mills added.
    For more information on AO-40, visit the AMSAT-DL Web site,
    or the AMSAT-NA Web site.
ad: cq2k-1
