ad: CQMM-1
AnyTone AT-D878UV In-Depth Review – DMR HT with APRS!
Discussion in 'Amateur Radio News' started by VA2PV, Jan 2, 2019.
  1. WB2YMU
    WB2YMU Ham Member QRZ Page
    Can this radio be used in dual band RX IE vhf/uhf ...vhf/vhf etc in the vfo mode...Interested for SAT work...???
  2. IW2BSF
    IW2BSF Ham Member QRZ Page
    i think NO for sat radio ues ... is not a REAL dualbander radio ... only one VFO RX work , hi !
    ROAMING PROBLEM
    the problem is that in all the world the DMR Network have two network the brandmeister and the dmr-plus !
    Here in italy the situation is very BAD... we have 3 separate dmr network , a very big problem too .
    For the creation of groups of roaming lists (for the 3 separate dmr networks) you can do it easily .... But the problem is that if two bridges of different networks and different id have the same frequency you will understand that even if you have done the two lists you can not discriminate the above mentioned bridge because the roaming system is based on the reception of the transmitted frequency and not with id dmr !!
    i not say if Motorola or Hytera radios his roaminf mode is based on the id-dmr repeaters ....
    the anytone 878 (and i think the new mobile 578 ) is based ONLY the scan in roaming for the frequencies... and this is not good for this problem of the two separate DMR NETWORK .
  3. KI6PMD
    KI6PMD Ham Member QRZ Page
    As far as working Satellite with a H.T. the best radios for that are the TH-D72 & TH-D74 Kenwood dual band & tri-band handheld radios they are very $$$ but with APRS & GPS + all the other GOODIES they can't be beat ! with these radios you can work the FM sats & the digi sats + the ISS !!! WOW ! 73' Phil KI6PMD..
    KC1OCA likes this.
  4. AD4ZU
    AD4ZU Ham Member QRZ Page
    If this radio works on APRS I'll be glad to see it. If anyone on this thread needs help with APRS programming, I can be reached at ad4zu.fl@gmail.com This, if in fact, has the capabilities of a Kenwood or Yaesu for APRS might be a good radio at $200.00. I really dislike DMR, so you won't find me purchasing one. But, again, if anyone needs help with understanding APRS, feel free to send an email. Happy to help. 73 Chris
  5. AD4ZU
    PART 90
  6. WB2YMU
    Thanks...was just wondering..
    I have a IC-51a I will evetually use for SAT work att....or my IC-5100a...
  7. K9GLS
    K9GLS Guest
    DA 18-801
  8. W4EAE
    W4EAE XML Subscriber QRZ Page
    What sort of information do you have that the Alinco will get APRS?
    I am asking because there doesn't even seem to be any factory firmware available, much less upgrades. Until 2 weeks ago, the DJ-MD5GP didn't even appear on the Alinco support website. Don't get me wrong, I really like the Alinco, and it does exactly what I originally bought it for. It is just that I am considering buying additional equipment for APRS, and I don't want to waste the money if I don't have to.
  9. IW2BSF
    ....... only a "rumors" ??? hi hi :)
  10. KK4HPY
    KK4HPY Ham Member QRZ Page
    There is another review by David Cassler on youtube where he investigates and proves it is FCC certified.
    IW2BSF likes this.
  11. IW2BSF
    please post the LINK ?
  12. IW2BSF
    NEWs about the future (in march 2019 ? ) Module Bluetooth optional:
    The D878UV radio will add a circuit board and an antenna inside the radio. The kit will also include an external Bluetooth PTT switch (powered by a battery and connected to the radio by pairing with the radio), so also a cellular type headset with a microphone paired to the radio.
    When used in a vehicle and paired with the car, the radio can play music and when an analog call or DMR arrives, the music on the radio will stop and the call will be heard over the car speaker. If you press the PTT button (velcro on the steering wheel), you use the microphone in the car !
    great !!! 73 de IW2BSF Rudy
  13. IW2BSF
    The very best of this module BT is that not used a mike and ear external (like a normal BT handset) but used the internal system audio of your car , GREAT !!!
    Thanks for this info to Trygve Svard
    Best 73 de IW2BSF - Rudy
  14. KB2UEW
    KB2UEW Ham Member QRZ Page
    nice video Pascual 73 good luck
  15. AD8BV
    AD8BV Ham Member QRZ Page
    I'm sure someones gotten to this first, but it has that spread because the anytone is type accepted for commercial use. (as long as the keypad programming remains disabled)
ad: M2Ant-1
