anyone built a 5/8 vertical for 10m
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by N4AEQ, Dec 2, 2008.
  1. N4AEQ
    N4AEQ Ham Member QRZ Page
    I looking for plans to build a 5/8 wave vertical for 10m. I keep thinking I will
    find a old CB 5/8 to convert at some yardsale or fleamarket but havent so far so
    and after having success building a colinear vertical for vhf now im ready to
    try again. Im trying to pickup a local traders net on 28.375, most checkins are in a 40 mile radius, I added a 10m leg to my HF dipole but signals to the sides are very very weak. I could easily build a 1/4wave but my thinking is a 5/8 with longer element would receiver much better.
  2. K7KBN
    K7KBN Ham Member QRZ Page
    It just might. Try it and see.
  3. WB2WIK
  4. KL7AJ
    CB antennas work fine for 10 with just a smidge of tweaking.
  5. PA5COR
    PA5COR Ham Member QRZ Page
    I was given a Imax 2000 with the ground radials from a cb station that quit.
    With just a bit extra ground wires it works fine on 10/12/15/17
    Working that like years, so i can choose between the OCF and the vertical
    Any cb 5/8 will work on 10 meters, just keep it a few inches shorter.
  6. KB5IAV
    KB5IAV Ham Member QRZ Page
    I knew a ham once who used a 5/8 wavelength CB antenna, a Shakespeare Big Stick, to work 10 meters and had good luck with it, working DX all over on it using a 25 watt Uniden HR2510. Of course, this was back around 1989 when the sunspots were higher than now. To answer your question, yes, it can be done.
  7. KC0TKS
    KC0TKS Ham Member QRZ Page
  8. N4AEQ
    Thanks for the reply your 10m J pole
    Looks like the kind of project I would like to try, the webpage has great closeup
    photos. I had thought of a 10m J pole before but alot of post say you have
    to isolate a J pole from all metal or it wont work. Guess you have actually done
    it and it works so this maybe my project for the coming Holidays.
  9. KI4SYR
    KI4SYR Ham Member QRZ Page
    Maco V-58
    I've been using a Maco V-58 for about 4 years, two of which was on CB. It worked great for CB and when I shortened it for 10m, its working better than ever. I used to use it a bunch for ground wave, but it even works great for DX. I've never needed more than 100w, most of the time just a 25w HTX-10 will do the trick.
    A local store was selling them for $65 back then, not sure on the price now, but I know they still offer them. Maco makes some fine antennas, and all aluminum construction. PM me for the local store number.
  10. CT2JUT
    CT2JUT Ham Member QRZ Page
    I have just built a 5/8 vertical antenna for 17m band with help from some antenna modeling software and ARRL antenna books.
    It does not work as good as i though (but it should outperform my 1/2 wave dipole also monobander for 17m) as the 5/8 vertical take-off angle is much more lower.
    Anyway, i´m still confused about the radials sizes, i´m using 1/4 elevated radials (as the antenna is on the building´s roof).
    According to software, the antenna will perform better with full wave size radials, also at 1/2 wave high.
    I wonder if anyone has some experience or opinios regarding improving my homemade antenna?
    It´s nicely matched with a tapped coil, it presents a low swr, but as we all now, this means nothing, even a dummy load will do.
    I´m looking for good performance like 3.3dBi and around 16º angle elevation.
    Any thoughts???
    Cheers in advance,
    Miguel
ad: hrd-2
