Antenna Tuner -- Replacing Roller Inductor With Switched
Discussion in 'Radio Circuits, Repair & Performance' started by KG7FIU, Jun 8, 2019.
  1. KG7FIU
    KG7FIU Ham Member QRZ Page
    Have an MFJ-989C antenna roller inductor tuner. But hate the inductor component. Loose contacts, grinding, lots of arcs, plus it takes forever to switch bands / QSY even when it does work properly.
    Wonder if it would be possible to swap out the roller inductor component with an old-fashioned multi-position switch component that would still handle higher power. Something like the inductor the MFJ-962C has (see picture).
    Has anyone done this? Would it require additional circuitry, etc?
  2. AF7XT
    AF7XT Ham Member QRZ Page
    The above example if only for lead dress is flawed.
    Placing the switch contacts as close to the inductor as possible is key.
    One good example included. A Drake MN2700B
  3. AI3V
    AI3V Ham Member QRZ Page
    It will work fine, and be a very easy, non-critical project.
    Try and use a coil about the same size, and a switch with as many positions as you can find.
    Rege
  4. KG7FIU
    ok, thank you for the feedback everyone!
  5. KD0CAC
    KD0CAC Ham Member QRZ Page
    Or you just solder to the coil that is in there .
    Just add a switch .
    G1OJS likes this.
