Antenna Modeling Software
Discussion in 'Amateur Radio Software' started by AF5AD, Mar 12, 2012.
  1. AF5AD
    AF5AD Ham Member QRZ Page
    I have a general question about antenna modeling software. When I use formulas for wavelength using the value adjusted for velocity factor of .95 (234/Mhz for vertical 1/4 wave) the answer is shorter, and seems more accurate, than using modeling software. MMANA and others seem to use the speed of light in a vacuum and therefore give answers indicating longer antennas.
    Why is this; can it be adjusted in the programs?
  2. AF5AD
    Extra research I've found that the velocity factor of .95 is for the wire; not in air which is actually .9997. Still don't know why MMANA doesn't consider this is calculation. I've selected cu wire for medium with little change.
