Amps in arrl handbook
Discussion in 'Amateur Radio Amplifiers' started by N8FWD, Jan 21, 2017.
  1. N8FWD
    N8FWD Ham Member QRZ Page
    Hello,
    Can anyone tell me what hf amp projects were in the past 15 years of the arrl handbook
    Thanks mike N8FWD
    AF6LJ likes this.
  2. AC8AC
    AC8AC Ham Member QRZ Page
    I cannot think of any . is there anything your looking for in particular
    AF6LJ likes this.
  3. N2EY
    N2EY Ham Member QRZ Page
    2013 Handbook:
    250 W amplifier (requires less than 10 watts of drive) for 160-6. SS, uses two VRF151s
    1500 W amplifier (grid driven, requires about 75 watts drive) for 160-10. Tube, using a single Eimac 3CX1500D7
    2017 Handbook:
    Same projects as above. There is also an "Everyham's Amplifier" project, which is more of a "how to design an amp based on parts you have" thing.
    AF6LJ and KJ4VTH like this.
  4. WB2WIK
    I only buy a new Handbook about every five years, but have several accumulated over a long time.
    If you're looking for a solid state amp design, those have been popular in the Handbook for the past 15 years; but if you're looking for a "variety" of vacuum tube designs from fairly low power (6146) to legal limit (8877 etc.), there's a lot more of those in much older Handbooks, from the 50s (pre-8877 days, but they have 4-1000As and stuff), the 60s (when many of the modern ceramic-metal power triodes were introduced) and 70s (more modern tube designs). The Handbooks from the 40s include amp designs using older tubes (807s, 811As, 813s, etc) which are kinda fun if you happen to like old tubes -- and better if you already have some.
    AF6LJ likes this.
  5. N8FWD
    I want to build an 8877 or dual 3-500 I want to use a full wave bride power supply
    AF6LJ likes this.
  6. WB2WIK
    A full wave bride might upset your wife if you're married.:)
    Amps like that are described in detail in the Radio Handbook by Orr, W6SAI, all of them published in the 60s and 70s. If you don't have one, they're easy to find on Amazon, and many libraries have them as well.
    AF6LJ likes this.
  7. WA7PRC
    WA7PRC Ham Member QRZ Page
    Start with a good transformer. You could do worse than the xfmr used in the Ameritron AL82/AL1500, pn 404-1418-1D (2570VAC @ 800mA).
    AF6LJ likes this.
  8. AC0OB
    AC0OB Subscriber QRZ Page
    Hi Mike. Home brewing is not only fun but satisfying in the sense that you have accomplished something...and it works!
    A few things to consider:
    1. What test instruments do you have? (1kW dummy load, multiple DMMS, power meters, oscilloscopes).
    2. What mechanical eqpt. do you have in drilling and punching sheet metal?
    3. Have you built anything electronic?
    4. What familiarity do you have with HV and safety precautions?
    5. How is your patience quotient?
    Phil
    AF6LJ likes this.
  9. K7MH
    K7MH Ham Member QRZ Page
    and 6...How deep are your pockets!
    I think it is very cool to build your own amplifier but if someone does not own or have access to the necessary test gear and mechanical equipment, the costs can go pretty sky high.
    AF6LJ and N2EY like this.
  10. K9STH
    K9STH Ham Member Staff Member QRZ Page
    MH:
    Add a well stocked "junque" box into the cost equation as well!
    AF6LJ likes this.
