ALS-600
Discussion in 'Amateur Radio Amplifiers' started by K4IE, May 17, 2019.
ad: DLSpec-1
  1. K4IE
    K4IE Ham Member QRZ Page
    My ALS-600 was working great until one evening I turned it on at it was completely dead. Checked all 3 fuses and they all checked good. What is my next step?
  2. W8MIB
    W8MIB Ham Member QRZ Page
    What type of power supply do you have?
  3. WB2WIK
    Repeat.
    The ALS-600 has two possible available power supplies from Ameritron. One is linear and dumb as a rock, the other is switchmode and more efficient, but also much more complicated.
  4. WB5WPA
    WB5WPA Ham Member QRZ Page
    Outside of a quick "fire sale", troubleshooting ... see WIK above too.
  5. K1MMI
    K1MMI Ham Member QRZ Page
    If you have the Linear power supply there are 2 fuses on the board inside the power supply F601 and F602.
    Maybe the ON/OFF switch on the Amp has gone bad. I'd also make sure the place where the AC power cord is being plugged in has AC power be it 120 or 240 VAC.
    Myself, I'd take the cover off the power supply and use a meter to make sure AC power is being applied to the power supply. Maybe, the AC cord is old and defective now.
  6. WD4BSU
    WD4BSU XML Subscriber QRZ Page
    Switching power supply? Is 50V present? 12V regulator was my problem.
    W1BR likes this.
  7. WB2WIK
    I guess this was a "hit & run" post, as the OP never returned.
    K0UO likes this.
  8. N8FVJ
    N8FVJ Ham Member QRZ Page
    Original poster bought a new amplifier?
  9. KD2ACO
    ... or he found something silly and doesn’t feel like getting roasted here.
