ad: w5yi
Allstar Node DTMF and Connection Issues
Discussion in 'Echolink/IRLP Tech Board' started by KI7TSY, Apr 23, 2019.
  1. KI7TSY
    KI7TSY Ham Member QRZ Page
    I have a few issue with my newly built Allstar node….I am new to Allstar. This is also my first post.
    Here is what IS working:
    I am running HamVoip’s most current image on a Raspberry Pi 2 with AriUSB interface connected to a old Icom Mobile radio with 100mb internet. I can ping allstarlink.org successfully. I have confirmed that my node is registered properly. During all functions my CPU % does not exceed 39%. I am able to SSH into my node. I have set all my audio levels both RX and TX. I can hear the timed auto ID every 10 min on my HT clearly. I hear all notifications like “Connection Failed” clearly.
    Here is what's NOT working:
    1. Using my HT (I have tried 3 different HT's) all DTMF commands will not work. Although while in CLI mode, I can see in the prompt my commands printing on the screen. For example: if I press " * 8 0 " on my HT I see * 8 0 on the CLI screen as if it is registering my command. But when doing this nothing happens and the command does not execute.
    2. When in CLI mode, when I type “rpt fun <mynodenumber> *80” nothing happens.
    3. When in CLI mode, when I type “rpt fun <mynodenumber> *3<nodenumber>” after about 2 min or so I will hear “connection failed” on my HT.
    Thank you for any advice you can give me.
    KI7TSY
  2. KA9JLM
    Are you fowarding the proper ports on your router ?
    Does *75 work ?
  3. KI7TSY
    1) I believe so. I am forwarding port 4560-4570 both TCP & UDP to the appropriate static IP i created for my Pi node. I am also forwarding port 22 for SSH.
    Yes *75 works, as do all other commands only when executing the command via CLI mode, all are just delayed. I also tried *75 command from my HT: While in CLI mode i can watch my DTMF commands print on the screen as i type them on my HT, but i get the same result, a very delayed transmission.
    Below I copied and pasted from my CLI prompt using *81 command 3 times in a row and waiting for a transmission to come through: (i added some notes on the side) :)
    megatronpi*CLI> rpt fun 40423 *81
    == Refreshing DNS lookups.
    -- <DAHDI/pseudo-910577296> Playing 'rpt/goodmorning' (language 'en') <----- waited 2 minutes after pressing enter to hear time only
    -- Hungup 'DAHDI/pseudo-743070810'
    -- <DAHDI/pseudo-910577296> Playing 'rpt/thetimeis' (language 'en')
    -- <DAHDI/pseudo-910577296> Playing 'digits/10' (language 'en')
    -- <DAHDI/pseudo-910577296> Playing 'digits/20' (language 'en')
    -- <DAHDI/pseudo-910577296> Playing 'digits/2' (language 'en')
    -- <DAHDI/pseudo-910577296> Playing 'digits/a-m' (language 'en')
    -- Hungup 'DAHDI/pseudo-910577296'
    -- <DAHDI/pseudo-1340441802> Playing 'rpt/goodmorning' (language 'en') <---- waited 4:30 min, heard time/node#/node ID
    -- Hungup 'DAHDI/pseudo-1340039904'
    -- <DAHDI/pseudo-502579315> Playing 'rpt/node' (language 'en')
    -- <DAHDI/pseudo-502579315> Playing 'digits/4' (language 'en')
    -- <DAHDI/pseudo-1340441802> Playing 'rpt/thetimeis' (language 'en')
    -- <DAHDI/pseudo-502579315> Playing 'digits/0' (language 'en')
    -- <DAHDI/pseudo-1340441802> Playing 'digits/10' (language 'en')
    -- <DAHDI/pseudo-502579315> Playing 'digits/2' (language 'en')
    -- <DAHDI/pseudo-1340441802> Playing 'digits/20' (language 'en')
    -- <DAHDI/pseudo-502579315> Playing 'digits/3' (language 'en')
    -- <DAHDI/pseudo-1340441802> Playing 'digits/7' (language 'en')
    -- <DAHDI/pseudo-502579315> Playing 'rpt/timeout' (language 'en')
    -- <DAHDI/pseudo-1340441802> Playing 'digits/a-m' (language 'en')
    -- Hungup 'DAHDI/pseudo-502579315'
    -- Hungup 'DAHDI/pseudo-1340441802'
    -- <DAHDI/pseudo-130052693> Playing '/etc/asterisk/local/node-id' (language 'en')
    -- Hungup 'DAHDI/pseudo-130052693'
    -- <DAHDI/pseudo-1478007524> Playing 'rpt/goodmorning' (language 'en') <----waited 4:50 min, heard time/node#
    -- Hungup 'DAHDI/pseudo-1017096760'
    -- <DAHDI/pseudo-2053747725> Playing 'rpt/node' (language 'en')
    -- <DAHDI/pseudo-2053747725> Playing 'digits/4' (language 'en')
    -- <DAHDI/pseudo-1478007524> Playing 'rpt/thetimeis' (language 'en')
    -- <DAHDI/pseudo-2053747725> Playing 'digits/0' (language 'en')
    -- <DAHDI/pseudo-1478007524> Playing 'digits/10' (language 'en')
    -- <DAHDI/pseudo-2053747725> Playing 'digits/2' (language 'en')
    -- <DAHDI/pseudo-1478007524> Playing 'digits/30' (language 'en')
    -- <DAHDI/pseudo-2053747725> Playing 'digits/3' (language 'en')
    -- <DAHDI/pseudo-1478007524> Playing 'digits/2' (language 'en')
    -- <DAHDI/pseudo-2053747725> Playing 'rpt/timeout' (language 'en')
    -- <DAHDI/pseudo-1478007524> Playing 'digits/a-m' (language 'en')
    -- Hungup 'DAHDI/pseudo-2053747725'
    -- Hungup 'DAHDI/pseudo-1478007524'
    I cant seem to find any patterns as to what is delaying all the commands.
    I get the same results whether i use CLI mode or my HT dtmf commands. Thanks for your input!
    KI7TSY
  4. KA9JLM
    Some delay is normal.
    You need to do a disconnect all (*76).
    If something is connected, It will send your Play command over the network. Until Play is done you will have a large delay.
    It looks to me that your delay is from Play.
    Good Luck.
