ad: vanity
ALL YA'LL MAY THINK I'M "NUTS": 1986 Transceiver for Antique Mercedes W-126.
Discussion in 'Ham Radio Discussions' started by K3CSA, Jan 4, 2013.
  1. K3CSA
    K3CSA Ham Member QRZ Page
    Greetings Friends,
    FYI, I'm buying a (relatively low mileage & in GREAT shape) 1986 Mercedes-Benz 300SDL (That's the W126, i.e., BIG, long-wheelbase, 4-door Diesel saloon.), to restore & keep FOREVER.
    I have this "nutty notion" of equipping the M-B with a PROPER, which is to say a 1986-vintage, Dual-band 2M/440MHZ mobile ham radio transceiver & antenna, to "match" the car's vintage.
    IF you were going to attempt this project (NOT whether you think that it's a good idea. = I have several of those opinions.====> CHUCKLE.), WHICH transceiver & antenna would you pick as "a high quality" 2m/440 rig of that period.
    Sincerely, Tex/K3CSA
  2. K9STH
    K9STH Ham Member QRZ Page
    There are all sorts of 2-meter FM transceivers from that era. However, finding a dual FM transceiver is going to be VERY difficult because such were just not being built in "those days", at least in any quantity.
    For an antenna for 2-meters, the Larsen NMO-150K has been in use, virtually unchanged, since the late 1960s. Those are an excellent choice for 2-meters.
  3. N2ADV
    N2ADV Premium Subscriber QRZ Page
  4. N0NB
    N0NB Subscriber QRZ Page
    As I recall the Kenwood TW-4000 came out in 1985 and one of the local new Techs from our 1985/'86 class bought one in early 1986.
  5. N9DSJ
    N9DSJ Ham Member QRZ Page
    I still use a TW4000A - great receiver even compared to more modern transceivers. Only thing that needed repair was the to be expected internal battery and dial lamps.
    Bill N9DSJ
  6. K7JEM
    K7JEM Ham Member QRZ Page
    Also the Icom 3200 came out in 85 or 86.
  7. WA8FOZ
    WA8FOZ Premium Subscriber QRZ Page
    Consider the Drake UV-3. Rarer than hens' teeth, but a fitting complement to a W-126. These predate the 1980's, but were still very much admired then. They are also quite a bit larger than the typical modern FM two-bander, but probably there would be room in the big M-B.
  8. K3CSA
    To ALL
    THANKS for the advice.
    I also should note that i NEED a rig with a TONE BOARD, as all the repeaters around here require them - IF i remember correctly the TW4000 series radios do NOT come that way.
    K3csa
  9. N9DSJ
    Mine has the Kenwood tone board - but needs to be programmed (from the bottom of the radio) via dip switch settings....one setting each for VHF and UHF....
  10. WB2WIK
    The tone board is the issue, as in those days the tone boards were DIP switch set, and you had an option of maybe 1-2-3 tones, if you were lucky.
    Howsumever, you could use "any old rig" and add a CTCSS encoder like the Com Spec TE-32 or TE-64 to it, outboard, and just hang that under or alongside the rig with some velcro or something.
    The Drake UV-3 sounded like a great idea to me, and you could add another band (they covered three bands, such as 144-222-440 MHz). Problem is finding one that works after all this time.
ad: ARR
