Kenwood will soon be introducing the Kenwood TS-2000 HF/50/144/440/1200 MHZ ALL MODE TRANSCEIVER <TABLE> <TR> <TD VALIGN="TOP"> <FONT SIZE=+1> Listed are some of the great features this NEW Transceiver has to offer. It is NOT type accepted from the FCC yet. A price has not been announced at this time. The radio will be available at the end of the year. The information presented is all that's available presently.</FONT> </TD> <TD> </TD> </TR> </TABLE> Power Output <UL> 10-160 Meters 100 Watts 50 MHZ 100 Watts 144 MHZ 100 Watts 440 MHZ 50 Watts 1200 MHZ 10 Watts [*]Built-in Automatic Antenna Tuner that cover (HF/50 MHZ) [*]Built-in 2-Chip TNC (1200/9600bps) [*]Kenwood Sky Command System (Remote HF control with a TH-D7A, & TM-D700A) [*]DX Packet Cluster Information (scrolls the information in the Sub Band) For example; when you are listening to 20 meters in the main band you have the 2 meter DX Cluster frequency in the sub band with the TNC engaged if a DX spot comes up the FREQUENCY/ UTC TIME/ AND THE DX STATIONS CALL SIGN WILL BE DISPLAYED ON THE SCREEN. [*]IF DSP in the Main Band, and AF DSP in the Sub Band [*]Auto Tracking Satellite Functions (cross-mode compatible) Full IF DSP, (THIS IS A FULLY FUNCTIONING SATELLITE SPLIT OPERATION 144/440 MHZ ALL MODE TRANSCEIVER IN THE MAIN BAND, DO NOT LET THE SUB BAND RECEIVER CONFUSE YOU.) [*]RX in the Main Band is (30 KHZ-60 MHZ, 142-152 MHZ, 420-450 MHZ, 1240-1300 MHZ) [*]RX in the Sub Band is (118-174 MHZ, 220-512 MHZ FM/AM Modes Only) [*]This fantastic TRANSCEIVER will be offered in THREE configurations <UL> <LI>One complete unit with the front display (Large Amber LCD) <LI>"Black Box" with (smaller) mobile head that will mount in the front of a vehicle. <LI>"Black Box" that can connected directly to a PC via the RS232 port, and can be controlled with the RCP software. [/list] [*]Built-in Preamplifier [*]Built-in Keyer [*]TWO Receivers Main, and Sub Band (Simultaneous reception on TWO bands is possible) [*]HF by VHF/UHF, VHF by VHF, UHF by UHF, VHF by UHF [*]Built-in CW Auto Tune [*]Auto Notch [*]Beat Cancel [*]+- 0.5 ppm high-stability oscillator (-10 deg.C ~ + 35 deg.C) [*]5 Antenna ports [*]RX antenna connection [*]Large Amber LCD display has a slanted aero dynamic look, and all the front panel button are BACK-LIT in darkness you may see all the keys, and their functions. [*]Direct RS-232 port on the rear panel, you do not need to buy any external interface unit to connect it to your PC, its just a snap DB-9 to DB-9 straight cable that's it... [*]It is a 12 volt unit and uses the same mobile bracket as the TS-430S, 440S, 140S, 680S, 690S, 450S, 570D/S [/list] Kenwood TS-2000 PDF Flier
