AL-811H tube swap to 572Bs
Discussion in 'Amateur Radio Amplifiers' started by KW4GT, May 12, 2019.
ad: DLSpec-1
  1. N8FVJ
    N8FVJ Ham Member QRZ Page
    Oh, I did not read the four tube AL-811H has adjustable neutralization plate. Best to leave it alone unless the amp shows instability. I believe some older amps such as the Collins 30L-1 did not have neutralization- bad news.
  2. KW4GT
    KW4GT Ham Member QRZ Page
    Apparently the 572Bs are 'close enough'. I'm good with leaving it alone.
  3. KA9JLM
    Bend to adjust. :rolleyes:
  4. N8FVJ
    BTW- HRO (Ham Radio Outlet) shows to have Svetlana 572B tubes still in stock at $89 each. If so I would rather own these vs Chinese. New old stock needs to have filaments lighted for 2 hours before HV applied. Filaments and plate have a getter material applied to maintain vacuum and is activated with heat. After HV is applied, try to heat tube plate with constant carrier to heat up the plate to finish the re-evacuation. 10 minutes should be enough time.
