ad: rfparts
ADIF upload does not work
Discussion in 'Logbook User Forum' started by IZ2TWX, Apr 27, 2012.
  1. IZ2TWX
    IZ2TWX Ham Member QRZ Page
    Hello everyone, I uploaded my log from ADIF few days but do not see them in my logbook, what should I do? thanks
  2. W1DQ
    W1DQ QRZ Staff / Logbook Administrator Volunteer Moderator Platinum Subscriber Volunteer DX Helper QRZ Page
    Unsure that this will work but give it a try:
    Open your logbook
    On the left hand side of the Control tab section, click on the "Refresh Page" icon (two circular arrows).
    This normally refreshes all the records in your logbook and brings them into view.
  3. IZ2TWX
    I tried but not working
  4. W1DQ
    For test purposes I just uploaded a short ADIF file with only 1 or 2 records that I have since deleted. I found that the upload did work and the records appeared in my logbook. Perhaps your upload failed in some manner.
    I suggest that for test purposes you create a short ADIF file with only 1 or 2 records and try to upload it. These records can next be deleted, if so desired. If this file is accepted then retry your original upload.
  5. IZ2TWX
    ho provato ma non funziona nemmeno con 1 record:(
  6. IZ2TWX
    I tried but it did not work either with 1 record :(
  7. IZ2TWX
    I understand the problem, not me them wound up 'cause I used a logbook by hrd callsign / 2, I tried to remove the / 2 and now it works, why is this?
  8. W1DQ
    The file that you upload must be in the correct format according to ADIF protocal, refer to www.adif.org, latest revison.
  9. W1DQ
    I understand now. I see that you are no longer in Caserta but have moved to Varese. It seems that you tried to upload records using the call IZ8TWX/2 to your logbook which is for callsign IZ8TWX but without the /2.
    The current revision of QRZ only provides a logbook for IZ8TWK, not IZ8TWK/2. A new revision is under development that, when released, will allow you to create an additional logbook for IZ8TWX/2. I do not know when this new revision will be completed.
  10. IZ2TWX
    thanks all
