adi export
Discussion in 'Logbook User Forum' started by KZ4KX, Aug 26, 2019.
  1. KZ4KX
    KZ4KX XML Subscriber QRZ Page
    I have been looking through the threads but cant find it. I need to export qso logs but only the last 2 days and I am afraid of what might happen. I dont want to erase my log by accident.
  2. W1DQ
    Open your logbook
    Create a New View (on the Viewing pull down menu)
    Select field QSO Start Date then select "between" and enter dates
    Then click on ADD RULE
    Once correct display arrives click on View Options Export
    To do a different range, delete the created View and re-do.
  3. KZ4KX
    Thanks, I will try it. I got interested in the JT9 event and did not have the dx logger running and had to log all on qrz. The event organizer wanted a adi file and I have not done that before. I thought the wsjt program would log it but when I try to export it looks like jiberish.
  4. W1DQ
    An ADIF file (.adi) is a text file organized per ADIF protocol, see: www.adif.org
    It can be read and edited with a text editor, however it is extensive and you might consider it as jiberish-looking.
  5. KP4SX
    KP4SX XML Subscriber QRZ Page
    ADIF Master is a good simple program for reading ADIF files.
