A question for DXers, just got a hex beam, need some advise...
Discussion in 'Ham Radio Discussions' started by KB4MNG, Dec 28, 2012.
  1. KB4MNG
    KB4MNG Ham Member QRZ Page
    Last week I went from a rotatable dipole to a hex beam I'm very happy with it's performance. Around dusk, I try to work japan on 15 meter cw. On the dipole I had moderate success when conditions were right. Yesterday, I heard japan for the first time since installing the hex beam. To my surprise, I rotated the hex the full range and never peaked the signal, it stayed the same.
    I live in eastern NC. About 100 mi from the coast, center of the state. What direction does my beam need to be pointing considering the grey line. Also, I'm not sure I'm on the grey line 100% of the time.
    KB4MNG:cool:
  2. KB9UWU
    KB9UWU Ham Member QRZ Page
    How high is your antenna?
    To find the direction to any station, look them up on QRZ, click info and read the "bearing" direction.
  3. N7SMI
    N7SMI XML Subscriber QRZ Page
    Beam direction from Central NY to Japan will be around 330 degrees.
    The hexbeam seems much more directional on transmit than on receive, though you'll certainly want to be pointing toward the incoming signal. With that said, you sometimes won't hear a difference in signal strength regardless of where your beam is pointed. This seems particularly true of very strong and sometimes very weak signals.
    I'm not sure I understand your statement about the gray line. You'll only be "on the gray line" twice per day - once at sunrise and once at sunset. The directions you'll point your beam to follow the gray line at those times varies a bit based on the time of year - the angle of the gray line at your location changes with the seasons. In general, the morning gray line for the US favors Europe and Africa (beam Northeast) while the evening gray line favors Asia (beam Northwest) and S. America (beam Southeast). In other words, your propagation to Japan in the morning is not gray line.
    You can see gray line maps at http://www.w8mrc.com/dx/propagation/
  4. WB2WIK
    Yeah, nobody's on grey line for very long, since it's continuously moving at about 1100 mph.
    But from NC to JA isn't a tough shot; if 15m doesn't work well, try 17m, it can be better. Your short path beam heading is indeed about 330 degrees, but a Hexbeam is probably +/- 30 degrees wide at -3 dB points, so don't go too crazy about precision.
    I'd think if you notice no difference at all as you rotate the antenna, something's not right. Could be the antenna's too close to the ground or some other reflective surface (metal roof?).
  5. M3KXZ
    M3KXZ Ham Member QRZ Page
    Brian, if you want to look more at propagation, grey line, path predictions, bearings etc, then it's worth downloading the VOAPROP and/or HAMCAP programs. Both very simple and intuitive to use.
  6. KB9UWU
    I use a hexbeam, see http://www.k4kio.com for a picture of my antenna. I'm not sure how the antenna could RX differently than it can TX. Anyway, if the antenna is only up 20 or 25', it won't be very directional.
  7. KB4MNG
    The hex is about 30 feet. Normally there is a big difference rotating the hex on a signal but that was not the case with japan.
    thanks
  8. G0GQK
    G0GQK Ham Member QRZ Page
    On 10 and 15 metres point your antenna towards Europe when the sun is setting in the UK about 16.00 UTC, it won't last long, about half an hour
    Mel G0GQK
