A question about modern TV broadcast signals
Discussion in 'VHF/UHF - 50Mhz and Beyond' started by KC0BUS, Nov 28, 2017.
  1. KA9JLM
    That is not a Boob Tube, It is LCD.
    I guess the back lighting is a tube. But that don't count.
  2. ND5Y
    ND5Y Ham Member QRZ Page
  3. K3RW
    K3RW Ham Member QRZ Page
    Depends what you think DX means. If you mean capturing signals from the other part of the state, with a long boom yagi with high enough gain, you should get 100+ miles depending on the topography. For DX in other terms, you'd be better off to get a FTA satellite receiver and pick up some of the non-church/non-foreign channels. A few are broadcasting in the clear, but on satellite. Even better yet, a lot of local stations stream online and you can watch them for free. Or if you really want to see some neat ones, download Kodi and add-in some plug-ins on your PC and watch worldwide feeds.
    And with the CRT tv, you'd need a digital to analog box as many have noted.
    There are a few analog-only broadcasts still running as I understand--but VERY few in very rural places.
    Good news for the ATV crowd, is that all the old ATV equipment was analog. Newer stuff out of Europe costs a fortune and is digital. I've been able to use Sony and Casio portable TV receivers from the 80s to pickup my own signals. Really helps that we're using analog and those never were digital. And with a converter box and plug-in, I can pickup the local stations on digital too.
  4. W6RZ
    W6RZ Ham Member QRZ Page
    K3RW likes this.
  5. N5WVR
    N5WVR Ham Member QRZ Page
    Our local reception is very poor because I live in the mountains, and the local broadcast stations are about 30 miles away across two mountain ranges. They are not line of sight.
    The website TV Fool lets you input a location and gives you estimates of signal strength at your location. I've found it to be pretty accurate.
    At my location, I had to put the highest-gain UHF yagi I could find on a rotor and add a pre-amp where the coax comes into the house, and it's still somewhat marginal. Putting the pre-amp at the antenna feedpoint would be better, but I didn't want to deal with the complexity.
    And this isn't "DX" -- these are my closest local stations!
  6. K8JD
    K8JD Ham Member QRZ Page
    I still don't get the "virtual" channel and when they say one channel on the ID but are on a different channel over-the-air :eek: ????
  7. ND5Y
    That's correct. The virtual channel is how they ID and probably the channel you select on your TV (I have never used OTA DTV so I'm nor certain how that works).
    This is not the same as the actual RF channel used. Usually the virtual channel is the same as the old analog RF channel.
    It's no different than programming a repeater memory in any modern VHF/UHF radio and setting it to show a channel number, name or alpha tag instead of the frequency.
  8. KD4MOJ
    KD4MOJ Database Subscriber QRZ Page
    I'm trying to GIVE AWAY my 60 inch Sony LCD (old style ... it's really BIG). Can't get someone to haul it off.
    ..DOUG
    KD4MOJ
