A funny thing that happened in my ground system
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by N8WWM, Apr 9, 2012.
  1. N8WWM
    N8WWM Ham Member QRZ Page
    I bonded my operating and work benches with 8 gauge wire and good clamps and then clamped it all to the water pipe that passes through the basement crawl space, this was back in 2007.
    Last month I dug out some tubing for an antenna project out of the pile standing next to one of the table legs.
    Suprise!!!!!
    A piece of 3/8 in tubing had somehow lodged between the wall and the steel table leg. That piece had about 6 inches of totally disintegrated and useless mush. That end was about like aluminum foil.
    Anyone want to comment on just what was happening there?
    73 Doug
  2. KB4QAA
    Two words: Galvanic corrosion, oh two more: Dissimilar metal corrosion.
    You got the worst of both worlds.
    Somehow you set up ground loop with a potential above the electrical system ground, the wall?, floor?, tubing of different reactivities and your bench grounds. Over five years it only takes tiny fractions of a volt.
    First off I would not ground the two benches together. In any ground system each unit must ground to a central point, not each other. Time to re-examin your setup. Another possibility is that the electrical ground system may not be adequate, that is have too high a resistance.
    Congratulations on this years' science fair prize! :)
  3. KB4QAA
    Dupe, system running slow.
