ad: IACantenna-1
800 MHz "Trunk System" Receivers
Discussion in 'General Technical Questions and Answers' started by KG4LLQ, Feb 8, 2018.
  1. K3RLD
    K3RLD Ham Member QRZ Page
    Keep in mind that any Uniden product that uses the free sentinel programming software gets free weekly updates of country wide radio systems (sourced directly from Radio Reference). Bottom line is no RR subscription is required if you are using a Uniden scanner with Sentinel software.
    Downside here is Sentinel only seems to work in windows, won't connect to the scanner under WINE/Linux (at least for me).
    Different trunked systems definitely exist.
    upload_2018-2-13_10-16-8.jpeg upload_2018-2-13_10-16-18.jpeg upload_2018-2-13_10-16-41.jpeg
    K9ASE and NH7RO like this.
  3. ND5Y
    ND5Y Ham Member QRZ Page
    That sounds like a port permission problem.
  4. KD4MOJ
    KD4MOJ Database Subscriber Platinum Subscriber QRZ Page
    Seek and ye shall receive:
    ...DOUG
    KD4MOJ
  5. K3RLD
    Almost definately - however that's above my pay grade when it comes to linux... I could never get it figured out.
  6. NH7RO
    NH7RO Ham Member QRZ Page
    I never gave it much thought as to the origin of these trunked systems---I was kind of bummed out at the time they came into use since I could no longer receive a lot of stuff I had listened to in analog days---little did I know they actually originated in Africa and South Asia!
    Thanks for the interesting update, Steve. Makes me wonder about the origin of Uniden and Bearcat, though---their production could have started in a lion's den or bear's lair or something like that if my hunch is correct.
  7. AA5MT
    AA5MT Ham Member QRZ Page
  8. K4AGO
    K4AGO Ham Member QRZ Page
    Yes, they are called Trunk Tracking Scanners.
  9. K8JD
    K8JD Ham Member QRZ Page
    Uniden trunk tracker I got was only analog, I don't think my model could be set up with a upgrade digi system decoder board. no socket inside for one. . newer versions had a socket for a digi upgrade board but that was $$$ expensive !
  10. N3DT
    N3DT Ham Member QRZ Page
    The OP would be best served to go to radioreference and look up his area to find out what kind of signals are in his area and buy a scanner that will work with that system. However if the system is secure he's out of luck. I'm not sure many have secured their systems except for the feds. They've been secured since about 2005.
