64 Bit Windows 7 and Ham Radio Deluxe (HRD)
Discussion in 'Computers, Hardware, and Operating Systems' started by KL7SG, Dec 12, 2009.
  1. KL7SG
    KL7SG XML Subscriber QRZ Page
    If you are having trouble with HRD and your computer sound card under the new 64 bit Windows 7 update, here is a solution. The new Windows 7 driver will not properly initialize a Realtek sound card. The old Vista 64 bit sound card driver will work fine. This driver is probably still on your computer.
    This can be reinstalled by using the update hardware feature and selecting search for an updated driver on your hard drive. The old Vista driver will be one of the options.
    Cheers and Merry Christmas
    Mike
    KL7SG
  2. N2RJ
    N2RJ XML Subscriber QRZ Page
    Hmm I did not know that.
    My laptop has realtek HD audio with the win 7 driver and runs HRD just fine.
  3. KL7SG
    The driver is Version 6.0.1.5830, dated 4/10/2009.
    When this version is loaded, some software can't access the microphone audio. For example, Windows 7 can't run the native windows speech to text software.
    It may be just the version that came with the Windows 7 upgrade that ACER sent for my laptop.
    Cheers,
    Mike
  4. WD0MYM
    WD0MYM Ham Member QRZ Page
    I am running a brand new HP laptop with Windows 7 64 bit. I use a Signalink USB and have used two different cat cables. One is the stock Yaesu cable with the Keyspan adapter. The other cable is from RT Systems (it is USB and does not require an adapter). Both cat cable work perfectly with Ham Radio Deluxe and DM780.
    The only tricky part was setting the output of the computer correctly for transmitting. It is different than it was for XP. Signalink has a page about it on the website. My wife had to help me, we had it figured out in less than a couple minutes.
    I had to turn the sound level down quite a bit, as it is real hot. Lets me keep my Signalink "TX" at the 12:00 position and the digital gain on my 857D about 30.
    Jon
    WD0MYM
ad: GNOHF-1
