572 tubes update
Discussion in 'Amateur Radio Amplifiers' started by W8JX, May 15, 2015.
  1. W8JX
    W8JX Ham Member QRZ Page
    Pump is most important. A lot crap out around 28 or 29 inches of vacuum.
  2. G3YRO
    G3YRO Ham Member QRZ Page
    Well I guess it depends how hard you are pushing them. I don't normally get any glowing on SSB.
    But if you run at full power on CW and are sending slowly (like I often do for DX on 160) it can mean a long over with long characters . . .
    As Carl said, these valves are massively under-rated in these amps, so the anodes are bound to get pretty hot when used like that.
    I guess it's also subjective - what you describe as a glow may be what I call red ! (and I've never seen them go orange)
  3. KM1H
    KM1H Ham Member QRZ Page
    The SB-1000 is a cost reduced AL-80A and was designed by Ameritron. Before that was the AL-80 and before that the L-75.
    Carl
  4. WB2WIK
    Can someone tell me what pulling a vacuum externally to a vaccum tube does. I'd really like to know. Never tried it, but I'm trying to figure how that helps.
    If a vacuum tube has a leak that let air in, pulling an external vacuum may help evacuate the tube, but the leak remains. Kind of like pumping up a flat tire...might work for a short while, but if you didn't fix the leak, it will just go flat again.
    Guess I'm not getting how it helps.
  5. KA0HCP
    Come on Steve. Everyone knows the way to fix leaky valves is with Bar's Leaks....
    That or two cups of oatmeal! :)
  6. WB2WIK
    Yeah, I guess. Pretty temporary. A bit like touching up the X-rays because you can't afford the operation...
  7. KC9UDX
    KC9UDX Platinum Subscriber Platinum Subscriber Life Member QRZ Page
    Pulling a vacuum and heating the envelope might fix a 6146 I have. :p
  8. WB2WIK
    I'd love to hear how that helps.
  9. KC9UDX
    It wouldn't, but it's nice to think it would. It developed a short between the control grid and the screen grid, causing the plate to overheat and the envelope to partially collapse. I caught it before it had a chance to collapse far enough to implode.
  10. KA9JLM
    Yep.
    You have to seal the leak as soon as you remove the tube from the Vacuum chamber.
    Hard As Nails nail polish works good, and it will dry as it gets sucked onto the leak, and seals it.
    I use clear Hard-as-nails, Guess you could use colored to see where the leaks were easier. Not sure if the dye/color would cause Ark over, I have never use it. The Clear works fine.
    Have Fun, Save Tubes.
