ad: M2Ant-1
5/8 Wave Base Antenna, no luck
Discussion in 'General Technical Questions and Answers' started by CUCTU, Nov 24, 2008.
ad: K3QNTad-1
  1. CUCTU
    CUCTU QRZ Member
    Hi,
    I've had no luck with this antenna. I've made it basically as illustrated in another post here:
    I started with a 1/2" brass coupling and soldered #14 copper wire to the rim. Then I screwed in a 1/2" x 48" PVC pipe threaded on both ends to wrap the 10.5 turns and continued the copper wire straight up the pipe. Then I soldered on some brass rods through the coupling for radials.
    I did a 100 MHz to 200 MHz sweep to measure the vswr over this range and note the valley:
    r=20 x=6.5 ohms @ 135.70 MHz (vswr = 2.55, lowest)
    I tried shortening the "whip" and moving the tap, but not much really changed.
    Ironically, the vswr looks more promising up around 70cm:
    r=40.5 x=11 @ 434.10 MHz (vswr = 1.39)
    Smith chart (red is VHF, black is UHF, green are the markers above):
  2. K7JEM
    K7JEM Ham Member QRZ Page
    Try a series coil instead of a tapped coil. The coil will be about 3 turns of wire, about 1" in diameter, turns spaced with about one wire diameter.
    That should be about 9-10 inches of wire, overall. Adjust overall whip length to match SWR, but 48" will be a close start.
    The PVC pipe may affect the length, but if you sweep it you should see the match is good close to 2M.
    Make sure there is a good ground plane or radials in place, about 20" radials, 3 or 4 should work.
    Joe
  3. W5DXP
    W5DXP Ham Member QRZ Page
    Please describe your radial/ground-plane system.
  4. AC0FP
    AC0FP Ham Member QRZ Page
    There are some good suggestions here. The 5/8 wave antenna requires a good ground plane to work properly! Try measuring the antenna by itself, it should be capacitive and when the capacitance is tuned out with a small coil at the base of the antenna the impedance on the smith chart should rotate around to somewhere around 50 ohms +/- j 0.
    Frank:)
  5. CUCTU
    CUCTU QRZ Member
    2 rods, ~40" long (4 ground radials) are inserted perpendicular to each other through the brass coupling, about 1/4" and 3/8" down from the upper lip of the coupling so they cross in the center of the coupling.
  6. K8JD
    K8JD Ham Member QRZ Page
    On the comercial antennas I tore down , the coil feed tap is quite close to the ground end since it is operating a bit like an autotransformer where the larger end is toward the higher Z of the whip (2K?)and smaller turns toward the low Z (50 ohms) feedline.
  7. CUCTU
    CUCTU QRZ Member
    Moving the tap to 2 turns down from the whip made a big improvement.
    r=35 x=12.5 (vswr = 1.6) @ 155 MHz
  8. CUCTU
    CUCTU QRZ Member
    forgot the plot:
  9. KA4DPO
    KA4DPO Premium Subscriber QRZ Page
    That's definetly inductive reactance. Add a small piston capacitor, around 2 to 10 pf between the inductor and ground and see what you get. Better yet, make the antenna about 3 inches shorter.
  10. KA1MDA
    KA1MDA Ham Member QRZ Page
    According to my ARRL antenna handbook, coild form should be 3/4" diameter and 3 1/2" long. Coil consists of 10 1/2 turns of #10 or 12 wire. Whip is 47" long. Coax sheild connects to ground side of coil, coax center conductor is tapped approx 4 turns down from whip end of coil.
    I built one of these 2 meter 5/8 wave antennas about 20 years ago, and it worked fine just as described in the ARRL antenna handbook.
    Tom, KA1MDA
ad: hrd-2
