ad: GNOHF-1
220v for Yaesu FL-2000B amp
Discussion in 'Amateur Radio Amplifiers' started by KC9KQR, Oct 11, 2011.
  1. KC9KQR
    KC9KQR Ham Member QRZ Page
    I am trying to connect 220 volt inside the amp, and find the manual not much help. Would some one know the proper terminals to connect for 220 volt use. I also notice some terminals are doubled up also.
    Thanks much.
    The manual is great help, as it clearly shows exactly what to do on Page 4 of the manual.
    But the connections are clearly shown -- what's not helpful about the diagram?
  3. W9GB
    KQR -
    Carol Maher, W4CLM at FoxTango (Yaesu International User's Group) has the photos --
    what do you need to understand ?
    http://foxtango.org/foxtango001.htm
    SCROLL DOWN THIS PAGE -- DESCRIPTION and PHOTOS
    http://www.foxtango.org/amplifiers/FL Amplifier Evolution.htm
    Have you measured the actual voltage at your 240 VAC outlet ??
    In the USA, this voltage can be that high -- or higher.
    Properly Wiring your FL-2011B for 220/240 VAC ... it shows both USA (234 VAC) and Europe (220 VAC)
    READ and SELECT USA wiring !! ... 234 VAC -- the 117 VAC windings are wired in series.
    PHOTO of Proper Wiring for USA -- courtesy of Carol Maher, Fox Tango
    You WILL end up with an extra jumper when you go from 120 to 240 VAC.
    What are you using for a PLUG and RECEPTACLE ?
    NEMA Non-Locking Power Connectors (Straight Blade) - NEMA 6
    http://en.wikipedia.org/wiki/NEMA_connector#NEMA_6
    NEMA Locking Power Connectors (Twist-Lock) - NEMA L6
    http://en.wikipedia.org/wiki/NEMA_connector#NEMA_L6
    w9gb
  4. W9GB
    Wm -
    Did you get your Yaesu FL-2011b transformer (AC) primary wiring changed and operating on 240 VAC correctly ?
    w9gb
  5. KC9KQR
    Wiring
    I did get it wired up correctly. Thanks for the big help and smart ass comment wb2wik.
    Thanks for your help W9GB.
  6. N8WWM
    N8WWM Ham Member QRZ Page
    Give WIK some slack. He's been doing it so long his memories of being inexperienced are slowly being erased because of the new stuff fed in. Being a smartass is just his way of slowing the loss of data. :)
